- Fri Oct 25, 2013 5:35 pm
#338052
I'm about go nose deep into my car to figure out why it wont start and I'm posting this to see anyone else can brainstorm while I wrench.
New Battery. Fuses last I checked, are good. Main relay is good.
Tested starter in car and tried to jump it, it wouldn't spin. Pulled it out and took it to Autozone, and put in on their tester and it worked just fine.
When I turn the key, main relay kicks, fuel pump primes, lights dim, but all I hear is a constant click-click-click-click-click rapidly with no noise from the starter.
Help? I'm going check all the grounds and probably rebuild the ground that's on the transmission.
