- Sun Oct 20, 2013 7:30 pm
#337874
Pop it off, drain it out. If it's still heavy it's definitely not helping anything
- Fri Nov 08, 2013 2:17 pm
#338533
Well. I finally got it figured out. I had 2 cel codes: IAT and IACV. Turns out the IACV plug was plugged into the IAT, and vice versa. I swapped them and reset the computer, and i now only have an IAT code. But the tip of it is solid black so its probably just bad. But either way, the whole jerking issue is fixed and it runs as smooth as you please now.
- Fri Nov 08, 2013 7:02 pm
#338549
Glad you found the issue. i've heard that mixing those two plugs up can cause a short in the ecu so if what your planning doesnt work just pop the ecu open and make sure there are no burn marks. Easy 10min check
