ECU, Wiring, Sensors
By 92civicEGsedan
#332085 I got a sunpro air/fuel ratio gauge from my uncle today and I'm wanting To put it in my car but it doesn't have the wiring plug in to go into the back and was wondering if anyone here knew where I could get just the plug in and wires at? It's also the cp8200 if that helps
By HeikDiesel
#332090 ^This
By the time you mess around with all the wiring and trying to get it working on a stock narrowband you could just buy a used wideband
By 92civicEGsedan
#332116 It's more I just want it for looks then to be really useful since I have a mainly all stock engine and is pretty much useless till I Finnish saving for my k swap then I'd spend money on all that stuff
#332174 Power and illumination (parking lights) are found at the under dash fuse box. Get option plugs from the junkyard or use speaker connectors. Ground to the chassis with a ring terminal to the metal dash support or in the kick. O2 signal at the ECU harness.
http://www.civic-eg.com/causeforalarm/e ... ox_outputs
Looks like D14
http://technet.ff-squad.com/wiring.obd1.htm
Everything is the same except the O2
http://www.civic-eg.com/causeforalarm/a ... /index.php
By 92civicEGsedan
#332188 I guess no one understood what I was asking I need the wires that come with the gauge that plug into the back of it I know how to wire it and thanks suspended I won't have to re research it later when I hook it up
By 92civicEGsedan
#332240 Well I was messing with the gauge and a computer power supply to see if it would light up I found a 4 point plug in so I cut it off shaved down some non necessary plastic and it fit like a charm and works so I no longer need to know if I can buy that part ill be installing it tomorrow :thumb:
