ECU, Wiring, Sensors
By peteyparado
#329710 my cluster light bulbs seems to be ok.. the tach side comes on than couple nights later tach side dont work.. i tried checking out the dimmer switch seems to b fine.. could it b a loose connection behind the cluster.. need some help..
By rustyrex
#329714 When I swapped clusters I had the same issue. I had a couple loose bulbs. I didn't turn them in enough.
By peteyparado
#329753 ok i check it out..
