- Mon Mar 25, 2013 7:46 am
#329383
Hi,
Ive tried to do as much research on this topic as i can, but im still a bit lost with all the wiring..
I have a JDM EG4 - Carb that im going to install the ITR setup into. (front cut -- i want to use the ecu the motor came with - P73)
so basically.. carburetor to OBD2
im aware that the harness wont be a plug and play into the fuse boxes so what will i need to do?
just fyi my parts list is :
ITR harness - obd2
P73 ecu
EK hatch fuel lines
EK hatch fuel tank
b16 fuel pump
ITR Motor complete, hubs, shafts, linkage, tranny, engine mounts etc
ITR harness - obd2
P73 ecu
EK hatch fuel lines
EK hatch fuel tank
b16 fuel pump
