ECU, Wiring, Sensors
By slater
#323620 is there any other way to try and pull codes like putting an led light between the service connector or is there an obd 1 code puller? i dont feel like pulling apart the dash unless i absolutely have too
#323667 Maybe the bulb is just burned out. If so, that's not too hard to replace. You only have to take off the grey trim piece on the driver's side, then remove the cluster and put the new bulb in the back.
By slater
#323677 alright ill check that in the moring im hoping thats it, what bulb would i need to replace it with maybe just pull the seat belt one for the time being? im having some problems and really need to try and pull some codes to help narrow it down :x thanks teal
