- Fri Oct 19, 2012 3:39 pm
#318216
Can I run my vtec and knock sensor to my p06 to activate my vtec seleniod.or do I have toa vtec ecu?i have a p07?
your harness from the shock towers to the ecu might be wired already...if so the pin spots will already have a wire in the respective area....and if you have or are buying an engine harness with vtec all you will have to do is plug it in and you are set to go...if your car is not already wired for vtec and you are not buying a vtec engine harness you will have to run your own wires...but if you do i recommend making them two pieces instead of one long wire from the motor to the ecu...this way you can easily disconnect the wires at a later date if necessary...hope this helps
also here is some links that might help you out a bit more
http://i75.photobucket.com/albums/i303/ ... pinout.jpg
http://civic-eg.com/viewtopic.php?t=5736
EG8 Build: http://civic-eg.com/viewtopic.php?t=20985&highlight=
EK Build: http://civic-eg.com/viewtopic.php?t=257 ... highlight= SOLD
#10 of The Civic-EG.com Ferio Squad
