ECU, Wiring, Sensors
By rustyrex
#312030 I have a sunpro tach I am gonna use in my 95 cx hatch with a d16a6 swap. Can I run the signal wire for my taxh to the blue test wire in the drivers side of the engine bay instead of my coil. The coil is a msd blaster 2.
By jdmeg8
#312048 I believe there is one factory behind the cluster
By rustyrex
#312051 So I can just tap into the factory wire?
By jdmeg8
#312053 yes just splice into that blue wire should be good :thumb:
