ECU, Wiring, Sensors
By asianrob
#311268
EGCiviCKid wrote:Sweet so no need to wire vtec as im plugging a sir into vti harness..just the o2 sensor?
was your car originally Vtec?
By asianrob
#311391
EGCiviCKid wrote:Na non vtec dpfi obd0 LSi
k, you'll have to wire it for vtec and anything else it will need. from the ecu to the shock tower.
and since your Dual point fuel injection, you'll have to do a little bit more wiring, or change over interior harness from a car that had multipoint fuel injection.
By asianrob
#311477
EGCiviCKid wrote:Yer I have already swapped out that harness and replaced with obd1 sir loom
ah cool yea then everything should be plug in play lol i though you still had the original harness in.
By asianrob
#311522 hmm o2 should be fine. you can refer to those links if needed but everything should work out.
