- Sat Apr 14, 2012 12:34 am
#301771
I recently got a Apexi Power FC for my OBD1 94 civic ex manual ej1. The FC is OBD2A. Im making a converstion harness of my own from two plain extension harness's one OBD1 the other OBD2A
Going by two ecu pinouts and matching each sensor wire accordingly the OBD1 has 2 ICM (ignition control module) wires at pins 21 & 22 connector A (largest) where as the OBD2A system only has 1 ICM wire at pin 20 connector A (largest)
Anyone have any idea what i should do here? just use one ICM wire or the 2 and join into the obd2 ICM wire?
