ECU, Wiring, Sensors
By roy93
#298271 Bought a 94 4 door was running just doesn't respond to the ignition switch. I am probably resposable for this. After I moved the battery to the trunk I was checking all the cel codes it was throwing. I put it on charge and when I tried to start it it made some funny noises under the dash and now....nothing any help apprecoated guys
#298277 I would start by checking your fuses both in the under dash and under hood fuse boxes. The one that is blown will give you an idea of where the problem might be. Post which one is blown (if any) and we'll help. Since you just relocated the battery, I'd suspect it has something to do with that.
By roy93
#298560 well apparently i fried the battery somehow. so i will be going to the parts store and purchasing a new one lol.
