- Fri Mar 02, 2012 4:37 am
#296785
I can't seem the find the wire to tap into, to make my parking lights go off when locking/unlocking, I've tapped into many wires with no luck. I've messed with the polarity fuse in my viper alarm brain also and still can't figure out how to get it working. Any help is appreciated.
- Tue Mar 06, 2012 1:49 am
#297180
take a look at your fuse panel there are 5 identical plugs lined up right above the fuses it is the second one from the right juat put spade on the end of the wire and it will plug right in! oh yea dont take my word for it double check the wire prior to connection!
- Fri Mar 09, 2012 12:32 am
#297513
im looking for this wire too. the diagrams i looked up say its the red with black stripe wire. i tapped into 2 wire with that color and nothing. looking on and around fuse box under the steering wheel.
1995 Honda Civic DX Sedan
- Fri Mar 09, 2012 1:18 am
#297522
i tapped into the wire in the cluster harness, it will blink your parking lights and cluster lights tho. i can verify the color tomorrow but i believe it is red/black wire. it will be the only wire that color in the harness for the cluster.
- Fri Mar 09, 2012 2:34 am
#297532
please let us know what harness it comes off of. what color plug. tap from closer to the cluster side or to the other side. where ever that is. or even what row and how many pins over from the right/left.
this is bugging me. i found all the other wire no problem and they were mostly covered. i spent forever looking for this one...
thank you very much for your time by the way.
- Sat Mar 10, 2012 3:51 am
#297662
found it. i must have had a bad connection before. it was a wire i tapped into before.
remove the panel under the steering wheel via the 3 screws. this will make it easy to get to the wire. on my dx sedan it was the green plug on the top of the fuses. its kinda in the middle. from the left i had one 3 prong plug that wasn't there. might be there if you have a ex. then its the next plug over.
if you look at the green plug its the bottom row. theres 2 rows. and then the 2 wire from the right. the wire is red with a black strip running along it. it also has silver rings on it.
to test the wire. take the wire that you are going to tap into it with. expose the end of the wire and twist the loose wires together. then simply push it into the back end of the green plug where the red/black wire goes into. then test it.
i had it on my alarm to flash. press the alarm button and bingo. the lights blinked.
- Sun Mar 11, 2012 6:36 pm
#297816
very odd, how did you hook up the fuse in the control box?
I put my fuse polarity on "+"
pyang004 wrote:no i didnt have to.
wire was for my alarm to flash my lights. just one wire from the alarm brain to the red/black wire.
- Thu Mar 15, 2012 12:05 am
#298275
I have the 5701 but there's a fuse inside the box and according to the manual you have to choose either (-) or (+) for it to work, not sure why it won't work, I give up , I'll take it to the shop someday haha
