- Tue Jan 31, 2012 10:09 pm
#292786
the metal tabs inside the connectors do have power but for some reason its not lighting up.
- Wed Feb 01, 2012 1:36 am
#292805
i would go back through the wires and see what all same color wires you have and start traceing and doing checks on them all
My family man sedan
http://civic-eg.com/viewtopic.php?p=314391#314391
hgm b16a coupe build thread http://civic-eg.com/viewtopic.php?t=22844
teal dx dd build thread http://civic-eg.com/viewtopic.php?t=23254
- Wed Feb 01, 2012 7:58 pm
#292897
okay so small progress, i got all the lights working properly! so thats one thing down. today i'm doin some voltage drops with my dmm to test if all my sensors and whatnot are working. hopefully i find some problems!
- Thu Feb 02, 2012 12:41 pm
#293002
okay so now some not so good news. after i was testing my p/s harness i turned the key just to the on position! and BOOM a loud backfire and smoked poured out of my intake. i'm not sure what this means but i didn't assume it was good and then when i cranked it, it didn't pop or sputter anymore. since the DOHC engine is an interference engine maybe i could have dropped a valve or screwed the head if my timing was off?...
- Thu Feb 02, 2012 2:37 pm
#293019
pull the plugs and check the cylinders for parts. i'm not sure how you got ignition when the car wasnt cranking, But it sounds like you had unburnt fuel in the chambers from previous starting attempts and something set it off.
turbosedan717 wrote:okay so now some not so good news. after i was testing my p/s harness i turned the key just to the on position! and BOOM a loud backfire and smoked poured out of my intake. i'm not sure what this means but i didn't assume it was good and then when i cranked it, it didn't pop or sputter anymore. since the DOHC engine is an interference engine maybe i could have dropped a valve or screwed the head if my timing was off?...
- Thu Feb 02, 2012 3:50 pm
#293026
So what did you find to be the problem?
As far as the "dropped valve" comment, check mechanical timing via the belt and markings before assuming it was out of time. It would have to be out by quite a bit before it caused any damage, especially since hte car apparently hasnt ran in how long?
Anyway, pull the valve cover and check to see if everything lines up @ TDC. And go from there. If it checks out good, do a leak down/compression test.
turbosedan717 wrote:okay so small progress, i got all the lights working properly! so thats one thing down. today i'm doin some voltage drops with my dmm to test if all my sensors and whatnot are working. hopefully i find some problems!
RWMIII wrote:A little piss ant like you isnt worth being banned over.
EG6b20R wrote:Yea he has a bad habit of being overly sarcastic.. .. at the wrong times..
- Thu Feb 02, 2012 5:28 pm
#293044
That could still be the wrong order. I had this problem not to long ago, having the wires in the wrong order. I used the diagram for the d15b7 and it was wrong for my car, my # 1 was where two on the diagram was supposed to be.
EDIT: it's back firing out of your intake because your plugs wires are most likely WRONG.
put your number one cylinder at top dead center, remove your distruibuter cap and see where the rotor is pointing. If you've located TDC on the #1 cylinder correctly, you'll be able to tell for sure if the plug wires are right or wrong.
- Thu Feb 02, 2012 5:51 pm
#293046
well the headlights did just turn out to be the bulbs, switched out the aftermarket ones for my stock ones and yahtzee i have lights. but last time the engine did run the timing was off and it loped like crazy and just shut off thats why i feared the worst. but for the wrong firing order although unlikely i guess its still possible. i'll try reseting everything to TDC and see what happens. yesterday tho i was doing voltage drops on my engine harness and i had a 5 volt reference for my tps but my map wasn't getting any readings. i hooked my laptop up to the ecu and datalogged to look for any strange readings but map sensor and everything seemed fine.
By drivehrideh - Fri Feb 03, 2012 2:35 am
#293123
i am going with eg-guy defently still sounding like firing order issues if your firing order is right then your distribtor is wrong
eg-guy wrote:That could still be the wrong order. I had this problem not to long ago, having the wires in the wrong order. I used the diagram for the d15b7 and it was wrong for my car, my # 1 was where two on the diagram was supposed to be.
My family man sedan
- Sat Feb 04, 2012 9:27 pm
#293322
okay so little updates, there was a brown wire that was factory spliced into my main wires for my distributor that had a smalll gash in it with corrosion inside so i cut that out and resoldered it. now this seems like it could be a pretty serious problem other than it was a very small gash so i'll see if that does anything. and also can anyone elaborate how the gsr map sensor is wired up to a 92 shell that came with a firewall mounted map? my engine harness has a map sensor but yet my actual wires from the ecu for the map sensor are going to the empty plug for the factory one! and whenever i was testing my map sensor with everthing hooked up i couldn't get any voltage at the sensor in the engine harness.
- Wed Feb 08, 2012 9:58 pm
#293945
so i got the wiring for the map figured out now but still not starting. can anyone hook me up with a vacuum diagram for how the lines should be ran without a charcoal canister? i have pcv hooked to IM, FPR hooked to IM but idk where the lines for the map and that little tab on the back of the IM go.
- Sun Feb 12, 2012 9:24 pm
#294611
okay so i've got the right plug in the map sensor i have the vacuum line for the map t'd into the FPR line. but this made no effect on the starting
- Page 2 of 3
- 1
- 2
- 3
