ECU, Wiring, Sensors
By rated-EG
#291538 :shock:
#291539 To check the check engine light code, just use a paper clip :thumb:
Without checking the code, it's a shot in the dark and you're throwing $$$ at the car replacing parts until you guess the right sensor :thumb:
By rated-EG
#291540 :jawdrop
By 95c1v1c
#291617 Sounds like the same symptoms I had when my distributor coil went out. Of course you need to check your codes with the paper clip. Diagnostic harness is under passenger kick panel carpet, do a search for the shorting sequence.
By rated-EG
#291749 :eh:
By rated-EG
#291753 8)
By Hatch-O-Doom
#291756 Its not the wires in the ECU, You are looking for the wires right above it, kinda on the right side of the glovebox. there are 2 plugs plugged into a green holder thing.
unplug the one that has 2 wires in it, one will be brown the other not sure on color, i forgot at the moment.
then jump it with a paper clip/ or what ever your using. I used a cotterpin cuz thats all I had.
then your check engine light and SRS light will blink, One long blink is 10, one short blink is 1.
more then one code will be displayed by a longer blink between then, count the flashes and then tell us what you get.
By rated-EG
#291761 :eh:
By rated-EG
#291767 :)
By Hatch-O-Doom
#291877 okay, its the blue plug with one tan one green wire if I am correct... connect these to things via the paper clip. open paper clip up, and insert into plug as use as a jumper. and then it should start flashing, but you have to make sure its in there or it wont do absolutly anything...
http://honda-tech.com/showthread.php?t=1901557
thats one I used.
http://www.youtube.com/watch?v=b6rEk9aXOmg
This is pretty much what you are doing right there, dont pay attention to the color wires he is useing, but its pretty much same exact thing but different wires.
By 92civic_vx
#291885 i looked in my manual it says it should be a brown wire and a green/white wire that you jump to get the codes.
By rated-EG
#291969 :shock:
By 92civic_vx
#292036 you can reset it by either pulling the "back up" fuse under the hood, or disconecting the battery.
