ECU, Wiring, Sensors
By ForneyHatch
#278076 I know that there are tons of forums out there on how to convert an S2000 cluster into a EG. Tons of wiring is involved and other electrical modifications are needed. Does any website or individual sell a custom harness or conversion kit for this application. I know its not cheap to put in this cluster, but it just looks so awesome. Or, should I just bite the bullet and wire it myself like a man? Any input is appreciated, thanks.
By Dirtonaboi
#279140 The guage cluster will fit with minor fabrication?
By DontHateonEG8
#279235
Dirtonaboi wrote:The guage cluster will fit with minor fabrication?
not minor.
you need:
speed converter,
plate to which you can mount the s2k cluster to block of the holes
and a lot of wiring.
so depends on what you consider as minor i guess :)
