- Fri Oct 07, 2011 7:03 am
#276623
Hey have just put my car back together and have a code 6 water temp sensor coming up so want to just check other than the earth wire and the sensor that bolts into the block where the thermostat is, is there anywhere else I should check before I swap the sensor itself???
Also on cold start my car struggles to start and revs so low it cuts out would this be caused by the water temp sensor? And would water temp effect vtec as don't seem to be getting that either.
Thanks for your help in advance
