- Wed Oct 05, 2011 11:21 pm
#276407
does anyone know if you can tie into the negative and positive on your corner lights. that way every time you turn on your corner lights your fogs come on also? so you dont have to mess with the switch and fuses it runs strait from the bulbs to the wires on your corners..
matt is (eg6) wrote:does anyone know if you can tie into the negative and positive on your corner lights. that way every time you turn on your corner lights your fogs come on also? so you dont have to mess with the switch and fuses it runs strait from the bulbs to the wires on your corners..
Theres a way to do it. Idk how but my friend has it setup like that.
