- Fri Sep 16, 2011 6:35 pm
#272366
I have a couple sensors that aren't plugged in. I'm having trouble finding the plugs for them on the harness any help appreciated. One looks like the thermostat housing and the other is right above it below the hose that comes out of the valve cover. The last pic shows where both sensors are located in relation to eachother. I'm gonna go dig around some more for the plugs. Thanks
- Fri Sep 16, 2011 7:09 pm
#272368
I had a suspicion to check my engine code. All the D15B7's I've seen had the plug wires on the back side of the valve cover. Since I've looked up what engine was supposed to be in it I assumed I had the B7 without verifying. Found out I have a D15Z1, this engine is vtec right? That top sensor is the vtec solenoid? Other than that I am still missing the thermostat housing plug, does this engine or the B7 not have one cause I am not finding the plug. As for the vtec, is it ok to run this engine without vtec or would I get better performance/fuel mileage hooking up the vtec? This model seems to come out of the CX and VX. Hmm.....
*edit* I have a P06 ecu, this is not for the Z1 correct?
