Page 2 of 2
Sun Sep 11, 2011 3:49 pm
by HungRealLow21
i need help so my climate control lights are all out i mean they turn on when u press em but thats just the lil button lights and so are the rest of my button lights tlike the defroster and so on is there a fuse for that???!!!
Sun Sep 11, 2011 4:26 pm
by orangeEG
i wondered about a fuse for that aswell, when I bought the car it used to flash when I hit bumps but now it does not work at all, I could care less because I plan on changing to LEDs anyways
as for my previous issue about fuse #26 blowing it was my power wire to my cigaret lighter had chaffed on some metal and was grounding itself out, rerouted it around the metal and no more issues
Sun Sep 11, 2011 10:31 pm
by HungRealLow21
u know i was just bout to get to looking at all my wiring today but i let my wife take the car haha so imma deff do a whole wire chek cuz my radio be restarting everytime a blinker goes of or even just pushing the brakes in but imma do an led too just waiting for em to get here
Re: '92-'95 Civic Fuse Box Diagrams (Engine Bay and Under-Da
Wed Jul 04, 2012 7:23 pm
by redrix
Mon Sep 17, 2012 1:30 pm
by ceelx
i have a similar question. im just wondering if ill change my fuse box, nothing bad will happened ??
i wanted add power windows to my ferio but i dont have relay for them in my fuse box
this yellow relay does srs system i actually i dont need this cause i dont have any airbags.
so i need this one
the question is
will nothing screw up if ill change them ?? anybody know ??
Mon Sep 17, 2012 2:14 pm
by FG2_Andrew
It shouldn't mess anything up, iirc the fuze boxes basically are the same, just some slots are utilized, some aren't. Depending on the trim level of course!
Just swap all the fuzes over and you should be good. Should be like how all egs have the same climate bezel, but some slots are simply blocked off.
Mon Sep 17, 2012 2:21 pm
by ceelx
thanks
also i thought that all will be alright, but i was not sure
ill check this maybe tomorrow
Tue Sep 25, 2012 9:20 am
by ceelx
Fri Dec 28, 2012 6:21 pm
by FG2_Andrew
Fri Dec 28, 2012 6:43 pm
by Skillachie
You're a life saver thanks
Fri Jan 10, 2014 10:52 am
by silverEG8
engine bay:
under-dash:
[/quote]
Thanks Brah. Definitely useful, specially now.
Tue May 26, 2015 5:47 am
by dem0nk1d
Print as is and throw in your glove box!
Fri May 29, 2015 8:58 pm
by suspendedHatch
Sexy.
To the question about swapping fuse boxes, in some cases you'll have to swap over your ICU or else you'll lose intermittent wipers. In countries with options like daytime running lights that will also be affected. There are some relays that may need to swap over for sunroof, power windows etc.
