ECU, Wiring, Sensors
By FG2_Andrew
#315864 It shouldn't mess anything up, iirc the fuze boxes basically are the same, just some slots are utilized, some aren't. Depending on the trim level of course!
Just swap all the fuzes over and you should be good. Should be like how all egs have the same climate bezel, but some slots are simply blocked off.
By ceelx
#315865 thanks :thumb:
also i thought that all will be alright, but i was not sure :wink: ill check this maybe tomorrow :hehe:
By FG2_Andrew
#322916 so glad this is here! :thumb: :thumb: :thumb: :thumb:
By dem0nk1d
#353903 Image
Print as is and throw in your glove box!
#353967 Sexy.
To the question about swapping fuse boxes, in some cases you'll have to swap over your ICU or else you'll lose intermittent wipers. In countries with options like daytime running lights that will also be affected. There are some relays that may need to swap over for sunroof, power windows etc.
