- Sun Dec 05, 2010 6:59 pm
#226164
Hello everyone, well my fog lights were working gret for the past 3 or 4 monthes, then all of a suddon they stop working, i checked the fuse and it was fine, ai even changed it just incase it was blown and i didnt see it and still nothing. When i hit the switch, the relay clicks. I tucked the relay underneath my frame so water got to it, so i opened it up cleaned it up a little, then put it back together and it worked! then as soon as i tied it to the frame again it stoped working. Would this be the relay since its corroted soo bad even tho it still clicks when the button is pressed? thanks.
- Tue Dec 07, 2010 9:34 am
#226454
try replacing the relay
but also check the ground for the foglights them selfs
