How to wire a Resistor Box for low impedence injectors
When you are piecing together a turbo kit to save money, it's hard to drop a few hundred on some RC injectors. DSM 450cc's can be bought for about $50. However, you will need a resistor box to run them. A resistor box can be found for about $10. The resistor box will make the injectors the correct impedence to use with your ECU.
Here's a diagram I made:
