ECU, Wiring, Sensors
By -EJ1- COUPE
#17276 hey fitzy ill look into it more for you buddy
#17296 what pins on the plug are the wires in?
edit: this might help:
http://civic-eg.com/pics/ecu/ECU_pinout_obd1_2.jpg
Also I'm gonna move this thread to the electrical section :thumb:
By -EJ1- COUPE
#17312 thanks for the help teal thats one of my good buddies he just got a eg hatch with a y8 and weve been haven trouble with it
built-EGy8 wrote:Ive got my MAP all ready to be pinned but I have a little problem. There are 3 wires comming off of my MAP sensor. GRN/WHT,YLW/RED,andSolid WHT. which is pinned where in my harness?
Ok got it...
Green/White wire from the MAP sensor should change to Green/Blue after the main harness plug, and then goes to pin C11 on the P28
Yellow/Red wire from the MAP sensor should change to Yellow/Green after the main harness plug, and then goes to pin C10 on the P28
Solid White wire from the MAP sensor should change to Pink/White (93-95) or White (92) after the main harness plug, and then goes to pin C9 on the P28
