How to properly time a k series engine
today im ripping into an 02 acura rsx type s k20a2, my friend chirs is having timing issues since he purchased the car 2 months ago, he has a comptech supercharger and a kpro s-100 form comptech
im going to post up pictures of my civic as well so you know what you need to do in a eg, dc, ek chassis
heres a simple list of tools needed for the job
1/4" ratchet
10mm socket 1/4" drive (short and long)
12mm socket 1/4" drive (short)
14mm socket 1/4" drive (short)
3/8" ratchet
10mm socket 3/8" drive (short and long)
12mm socket 3/8" drive (short and long)
14mm socket 3/8" drive (short and long)
17mm socket 3/8" drive (short and long)
19mm socket 3/8" drive (short)
you can use regular box end open end wrench if you dont have the ratcheting style like i do
10mm ratchet wrench
12mm ratchet wrench
14mm ratchet wrench
17mm ratchet wrench
chain/pvc pipe wrench
(or impact and air compressor)
a decent sized nail
jack
jack stand
lug nut socket
pliers
bench vice
piece of a 2x4 if your scared about possibly damaging you oil pan with the jack
bucket to drain oil into
parts needed
hondabond or black silicone rtv
valve cover gasket
4.5 quarts of oil
brand new oil filter
if your not cheap like chirs lol
timing chain
tensioner
oil pump chain
front timing chain guide
rear timing chiain guide
rear oil pump chain guide
front oil pump chian guide
the best prices on the web for quality oem timing guide and chain is at www.clubrsx.com
click the parts section at the top of the page below the banner you cant miss it
here are some pictures of my civic eg jdm k20a to get started.
I am working on a rsx today, but I wanted to show you eg guys that there is not much difference in the process between the rsx and eg
youll have to jack your car up, brace the engine and pull this mount
next you will be taking your valve cover off
Now that your vc is off turn the crank pulley until its marks line up with the ones on the timing cover, zip that 19mm bolt out and your ready to take off the timing cover
lastly you will be pulling the timing cover off as carefully as possible there are 2 hidden bolts on these
OK! on to the rsx!
1/4" ratchet
3/8" ratchet
10mm ratchet wrench
12mm ratchet wrench
14mm ratchet wrench
17mm ratchet wrench
a decent sized nail
jack
jack stand
lug nut socket
pliers
bench vice
parts needed
valve cover gasket
4.5 quarts of oil
timing chain
tensioner
oil pump chain
OK! on to the rsx!
