- Mon Aug 10, 2015 3:58 am
#355229
DAMN!
sounds like a huge pain!
for 48 bucks, i cannot complain, since you can weld, i would stitch weld the new piece for added strength on the back side of it and inside of it, mark it with a sharpie first so you know were you can weld and were you need clearances.
good luck!
92civic_vx wrote:had the throw out bearing seize and destroy PP. so i put a stage 2 kit with lightweight flywheel in all was great for 3k miles then pedal popped (lost half pressure) and acted the same as before. so i got a oe clutch kit with master, everything installed bled out but still stuck in N when running. push clutch pedal in and have no pressure for half way then great pressure but it wont dis engauge fully. while changing MC i found my clutch pedal assy broken from the welds so i welded it back before installing. getting at this thing.
DAMN!
good luck!
"smoke me a kipper ill be back before breakfast" - ace rimmer
