- Thu Dec 18, 2008 4:10 am
#84355
If your going H22 then your not gonna need a huge turbo and alot of boost to achieve some really respectable numbers and thus your not going to need to re-sleeve the block. The H block will be fine under 10 psi of boost, and 7-10 psi in an H22 in an EG will pull like your heavily modded camaro. Look for a turbo that, like said above, is a "DSM" or T25- look for a smaller 'trim' - from .50 to .57 would be ideal. 'trim' is the difference in size between the fins of the turbine wheel at their smallest point in reference to the largest. The smaller trim number, the faster spool, the quicker you can plant the power. However, you'll sacrifice high RPM power for this low end spool. An H22 with a DSM turbo will have a powerband from probably 2000-5500 rpm, if you go with a T25 you may be able to extend those numbers by 500rpm. If you go with a GT28, slightly larger and more reliable then the DSM turbo's because they are dual ball bearing, you'll have a powerband from 3000-3500 all the way until redline. If I was going to do your build, this is my quick list of what to look for;
H22 motor
Turbo - A DSM TDO4 or TDO5, a T25, or Garrett GT28 - Selection of turbo depends on where you want your power to start and end.
turbo manifold flanged for t3/t4 turbo (or DSM if you buy a DSM turbo)
a good blow off valve - HKS, Greddy, or other comparable
a good wastegate - TIAL or comparable and have it loaded with a spring that will keep your boost beneath 9-10 psi (or run a boost controller to accomplish same thing)
all your charge piping and a good intercooler plus an adequate exhaust to let those gases escape.
This is your external kit in a nutshell, next your going to want to find your 'internal' parts which are going to be;
upgraded MAP
tuned ECU
upgraded injectors and maybe fuel rail
depending on mileage of motor your probably going to want to re-do all gaskets (if your getting a shop to do it like you say above then they'll probably do all this for you, but make sure you let them know you want it done because if you dont, they may not - even if it needs it).
do some reading on the reliability and capacitiy of the water and oil pumps as well, they may not be suited to boost from factory, or are just getting old and should be replaced as well.
Remember, you can find a good turbo, wastegate, blow off valve and even piping and hardware for alot less then the cost of buying new.. Do some shopping, save yourself some money
Anyways, sorry for the long-ish read, but if i can offer one last word of advice - quality never costs what it saves. Live by this, especially with turbo and supporting equipment.. This doesn't mean spend out the ass, but dont skimp, shop around for deals, and you'll end up with a good, fast, reliable product you can enjoy anytime!
Good Luck!
