- Thu Sep 25, 2008 1:38 am
#71406
Dubcity-EG wrote:well its not going to be raced it will be my dd but i want something thats going to have power and handle well at the same time.
Get a good D16 with I/H/E. It will be cheap, have ample power, It will get Good Econemy and handle well to.
to Swap to a B you will have to have at the Minimum the following:
- 94-01 Integra Shift Linkage
- 90-01 Integra B Series Axles
- B Series Engine/Tranny
- B Series ECU(Possibly Run Wires for Vtec and Knock Sensors as well)
- 94-01 Integra or Aftermarket B Series Mounts
If you swap to a H/F/K Series you will have to convert your car to run a Cable Transmission.
If you wont be Racing, A Good D16, Such as a D16z6, JDM D15B, or D16y8, Will probably do just fine for your Spited Daily Driving Needs.
If you will be Racing on top of it. A Turbo or Nitrous D16 is also good fun. However Swapping to a B or H Block would then Make Since. There's no point in having a B/H/K Series if you wont race it, it will just get you worse fuel econemy along with a lighter wallet.
