H22A
By 92dxeg
#228763 ok ppl i have a quick question my friend is doing a h22 swap in a ek and he wants me to post this question. ok he has an obd1 h22 how can he make it work with his obd2 civic ex harness
By Method
#228772 get a conversion harness.
By mooze
#228797 use ek harness...change connectors on injector plugs, dizzy, and alt to obd1 connector. can be found on any obd1 harness. use obd2 p13 and its done
By 92dxeg
#228803 "use ek harness...change connectors on injector plugs, dizzy, and alt to obd1 connector. can be found on any obd1 harness. use obd2 p13 and its done"
he wasthinking about useing a chiped p28 would that work wit this set up
By mooze
#228820 still works...instead of using obd2 p13 use obd2 (a/b) to obd1 converter cable and plug in p28
