H22A
By jrhdominos
#202227 Im getting ready to do an h23 swap into my car, and the stock fuel injectors are the peak and hold style injectors, which means you have to wire up a fuel injector resistor box, well Im wondering if I swapped my stock injectors for some 370cc RC injectors, would I still have to use the resistor box???
By mooze
#202793 depends.....if they are peak and hold yes.....
By jrhdominos
#204688 well I am speaking of the rc saturated injectors
By H22EJCIVIC
#204833 depends on if they are high or low resistence injectors there are two different ones so look close into that
By 92dxeg
#211553 so what is the best injector to run so you dont have to run the resitor box
By NanoCar
#219546
92dxeg wrote:so what is the best injector to run so you dont have to run the resitor box
Ok here's another stupid question. does the Fuel Injector Insert has nothing to do with oil additives? that stupid right? LOL
