- Sat Jul 28, 2007 3:07 pm
#17570
The H22A debuted in 1993 for use in the Honda Prelude VTEC as the H22A1. Versions of the H22A would be the Prelude's signature high-performance engine worldwide until the end of Prelude production in 2001. It was also used in the 1994?1997 Honda Accord SiR and 1998?2002 Honda Accord Euro-R in Japan (however different cams and lightweight crank were used in the Euro R H22A). The H22A in the Prelude Type-S and CL1 Euro-R came with the trademark red crackle finish valve cover.
Specifications
Bore ? Stroke: 87.0 ? 90.70 mm
Displacement: 2157 cc (132 cu. in.)
Valve Configuration: DOHC, 16 valves, VTEC
Type: In-line 4 cylinder, aluminum block and head
Compression ratio: 10.0:1 (North America); 10.6?11.0:1 (Japan)
Max power: 190PS (CD6 Accord); 200PS (BB1/4/6 Prelude SiR's); 220PS (Euro-R & Prelude Type-S) (142?164 kW)
Max torque: 156?163 ft?lbf (207?217 Nm)
Redline: 7500 rpm
Engine Control System: Honda Systems PGM-FI with port fuel injection
Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
Engine Oil Capacity w/ Filter: 5.1 Liters
H22A4
The H22A4 is the designation of the engine used in the Base and Type-SH 97-01 Honda Prelude.
This engine was only released in the US in all their models, and these are designated with the "black tops".
H22A8
This motor was only released within the European versions of the Prelude and can be designated with the "red tops".
H23A1
The H23A1 was an increased-stroke, non-VTEC version of the F22B, designed for the North American market version of the 1992?1996 Honda Prelude Si.
Specifications
Bore x Stroke: 87.0 x 95.0 mm
Displacement: 2258 cc (138 cu. in.)
Compression ratio: 9.8:1
Max power: 160 hp (119 kW)
Max torque: 163ft?lbf (207 Nm)
Redline: 6500 rpm
Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
Engine Oil Capacity w/ Filter: 114.5 Liters
There is also a DOHC VTEC version of the H23A, available in the CH6 and CL2(4WD) accord (CF4 wagon) SiR in Japan.
Specs remain largely similar to the H23A for North America, albeit differ in the introduction of VTEC mechanism and more power
Specifications
Compression ratio: 10.6:1
Max output : 200 PS @ 6800 rpm
Max torque : 220 Nm @ 5300 rpm
Redline: 7200 rpm
Specifications
Redline: 7500 rpm
H22A4
H22A8
H23A1
Specifications
Redline: 6500 rpm
Specifications
Redline: 7200 rpm
92 hatch build in progress.....
Snap-On Tools!
TEAM NSN to the fullest!!
East Coast is the Right Coast!!!
Snap-On Tools!
